SSC Klubben Sponsornyheter Greddy PRofec B Spec II
Visar 1 inlägg (av 1 totalt)
  • #21581
    PSR Racing
      Medlemmar i Svenska Subaru Impreza Klubben betalar 3515:- för GReddys PRofec B Spec II.
      LCD screen to monitor boost pressure in real time.
      Readout now in kPa or PSI. (100kPa = 1.01972kg/cm2 = 1.5psi)
      Controls boost up to 43 psi (This may vary on different turbo systems)
      There are 2 preset settings that can be selected by a single switch.
      The response and the consistency of the boost can be adjusted by using the GAIN, START BOOST setting.
      A built in warning feature will alert the driver when the boost exceeds the set boost pressure with an alarm and a message in the display.
      When the warning feature is activated, the LIMITER feature can lower the boost to a safe pressure.
      PEAK boost feature will allow the user to check the highest boost recorded.x(
      http://www.psr-racing.com
