› SSC › Annonser › Säljes – Delar › JDM AVCS Heads, TopFeed Conversion & more
- Detta ämne har 14 svar, 1,947 deltagare, och uppdaterades senast för 10 år, 7 månader sedan av
Hightone.
15 maj, 2015 kl. 23:27 #33713
Hightone
DeltagareEverything located in Goteborg.
Price is already really low on almost everything.
I am somewhat flexible on price.
Selling because I want to upgrade other stuff!
Il also accept trades!——————————————————
JDM EJ205 AVCS heads, they are EXACTLY the same as JDM STI V7 heads, big port heads!
They are in good shape!
4000sek shipping included! ***PENDING****
——————————————————Complete Intake manifold that is Topfeed along with rails. I deleted the TGV motors and ported them. 1500sek! PENDING SALE!
TGV Assembly Complete with motors 500sek (You can port these to get better flow!)
OEM STI Uppipe catless 500sek
OEM WRX Uppipe catted 500sek (I know in the USA you can sell the metal inside the cat for money)
2 bolt GTSPEC uppipe catless 600sek——————————————————
2 OEM Unequal Headers without uppipe 250sek a piece
02 WRX front and rear seats with doorcards FREEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
Just come get them out of my garage!
The front seats have been sitting outside under a patio, I would suggest a steam clean.
OEM boost controller 300sek
OEM 5 disc Stereo 500sek
Fidenza 5 speed Flywheel, installed but never ran! NEW PRICE 1000SEK! You pay shipping!
ACT Flyhweel 13LB I took it to get resurfaced but the machine shop messed it up slightly, so shoot me a offer, most likely can get fixed!
ACT Pressure plate inspected and looks usable! (Used)
ACT 6 puck clutch disc *spring* for 5 speed (BRAND NEW)
OFFER ME A PRICE!——————————————————
USDM 02 WRX ECU 300sek!
*Non AVCS version’
You can install Carberry rom on it which you can run lots of stuff like rally style anti lag, rotational idle, etc!——————————————————
TD04-HL 15t with kinugawa billet wastegate with a 1 BAR spring 1000sek!
This turbo came standerd on JDM WRX Ej205, turbo might need a rebuild, the billet wastegate is almost worth the 1000sek!16 maj, 2015 kl. 00:21 #276746karlberg
DeltagarePmd
16 maj, 2015 kl. 01:48 #276747Hightone
DeltagareReplied!
Also have a USDM 02 wrx ECU 16bit.Cant run avcs but you can run lots of other awesome things on this ecu.launch control etc etc
26 maj, 2015 kl. 05:45 #276748Hightone
DeltagareI also have a TD04-HL 15t, This turbo came standerd on JDM WRX Ej205.
It slightly bigger then the usual TD04 13t that most subaru wrx have.
I have ran this turbo personally and holds boost WAY better.I also put a kinugawa billet wastegate with a 1 BAR spring on it.
The turbo has water in the turbo inlet, not sure how to be honest.
So il sell this as a non working turbo. If no one purchases it il be rebuilding it with a billet wheel and converting it to a 19t wheel or bigger. Will be better and more reliable then a vf30.
10 juli, 2015 kl. 10:31 #276749Hightone
DeltagareHeads are still available. willing to accept trades. Send me a offer even if you think its a low offer.
14 juli, 2015 kl. 16:44 #276750Hightone
DeltagareI want 4000sek for the heads they need to go! These will be a perfect upgrade for any MY99 and below! Wire them up and gain low end torq and drivability!
23 augusti, 2015 kl. 10:26 #276751Hightone
DeltagareShoot me a Offer on the heads, they need to get out of my garage!
8 februari, 2016 kl. 11:57 #276752Hightone
DeltagareBumping this, things are up for sale again!
10 februari, 2016 kl. 22:30 #276753Hightone
DeltagareWilling to accept trades as well! Things I wouldnt mind
STI Genome exhaust
Oil Cooler (No Ebay)
S202 spoiler (Replica is fine)maybe other things just cant think of them, but cash would be better
I have Swish16 februari, 2016 kl. 21:10 #276754Hightone
DeltagareShoot me a offer! The intake manifold is perfect for those that want to switch from sidefeed injectors to topfeed injectors, that means better options for injectors and easier tuning!
Everything must go!
17 februari, 2016 kl. 10:04 #276758Baardh
DeltagareDoes the manifold fit v5 heads?
17 februari, 2016 kl. 13:11 #276755Hightone
DeltagareV1-4 use the regular bolt pattern, v5-10 use irregular bolt pattern.
So yes it should work on v5 heads.
Only small issue i could see is the pwer steering container might be in the way but i dont think it would be.17 februari, 2016 kl. 15:19 #276759Baardh
DeltagareYou got pm.
18 februari, 2016 kl. 09:51 #276756Hightone
Deltagare24 februari, 2016 kl. 22:24 #276757Hightone
DeltagareHeads and intake manifold are pending.
I need this stuff gone, offer a price! I really want everything gone! Garage needs to be cleared, tired of this stuff sitting around. I could use the extra money!
