SSC Annonser Köpes – Delar Looking for Silicon Houses!!
  • Detta ämne har 6 svar, 1,048 deltagare, och uppdaterades senast för 9 år sedan av Simon.x.
  • #34859
    Outlaw
      Hello,hello
      Im quite a Nooby hier so bear with me : D
      Im searching for silicon hoses for 2 gen 2003 Subaru Legacy 2,5 L motor With 115kw Automatic.
      The thing is that my Radiator Upper Hose Connection broke to do the fact that the Radiator hasen’t been changed and Was running still from the Factory.
      But to get a Perfect Flow I bought a fresh new Radiator and was planing on Flushing the system but in the changing Process one (the longer hose that comes from the left side) of the lower Smaller hoses got Destroyed.
      And after that i changed my mind. So now looking to replace the Upper 2 bigger hoses and also the 2 smaller that are under with SILICON HOSES
      For Reference i have exactly the same set up – https://youtu.be/NwT2o-gs07Q
      So if you have some SUBARU Silicon hoses laying around or know a place in Sweden where to get some then let me know. 😉
      #283353
      TomK
        House like this? 😀
        #283357
        Outlaw
          😛 Thats why i wrote down Bare with me 😛
          But enyway Cheers mate 😀
          #283354
          TomK
            I’m sorry but could not resist, you are looking for a HOSE
            #283355
            Zlasher
              Check out Do88
              #283358
              Outlaw
                Check out Do88
                Was there also but dident find the smaller hose that got broken. It looks almost the same as that –
                At the end where it shows Right line, there mine goes straight.
                Its called Lower Radiator Transmission cooler outlet hose
                Have been browsing the Web and there might be the Possibility that Knowone hase ever made that house out of silicon. If thats really the case then i have some new thoughts what to look for
                A/ Simple straight hose and bend that in place.
                Cons- It could be so off that it will squeeze the hose and no oil comes through
                B/ Similar one and bend it at the end and try do make it work
                C/ Get Subaru Standard hose and forget the Upgrade on that one
                Of course C is the last thing i want to do but lets be positive and Look what A and B will offer.d—0.o—b
                #283356
                Simon.x
                  House like this? 😀
                  Redan JUL 😮 d—0.o—b hehe
                  //Simon
