› SSC › Allmänt snack › Allmänt småprat › Front suspension knocking in 2007 WRX
- Detta ämne har 8 svar, 958 deltagare, och uppdaterades senast för 17 år, 3 månader sedan av
storfiskarn.
20 november, 2008 kl. 08:54 #10814
fpan
DeltagareIt seems like I have the dreaded front suspension knocking problem that is common is MY 06-07 cars. I searched in scoobynet and there are a lot of owners complaining about this issue, the front or rear shock absorbers knocking and they get replaced under warranty from the dealer.
Has anyone experienced this problem and how does the dealer diagnose it?
When I took my car for the 30k km service in Malmo the dealer said it is OK but the knocking is driving me nuts now.The car drives fine. The knocking occurs when the the road ’disappears’ i.e going up/down a kerb and only at slow speeds.
The car has Prodrive springs and the problem started 5k km after fitting the springs. At the same time I replaced the drop links with Whiteline rose joitned ones.
Someone told me it could be the coils of the spring touching (the rear springs have some plastic sleeve at the lower coils to prevent them from touching), I contacted Prodrive who told me it is either a faulty shock absorber or the spring is not seated correctly on the cap or something like that.Any help is greatly appreciated on how to diagnose the problem or get the dealer to change my struts as I don’t know what to do and don’t have the knowledge to fix this myself.
Thank you in advance for your help.
Fivos23 november, 2008 kl. 18:13 #118964storfiskarn
DeltagareI have prodrive springs and i have no problems like that. i have a 2005 wrx wagon,i think i had som plastik on the front springs to?
23 november, 2008 kl. 18:13 #118966storfiskarn
25 november, 2008 kl. 09:57 #118969fpan
Thanks storfiskarn!
I would appreciate if you could have a look and confirm that you have the plastic sleeve on the front or not(it can be seen in teh wheel arch, or worst case by slightly jacking the car up).
I am sure mine only have the plastic at the back 🙁
If that is the case I will have to remove the springs and fit a plastic sleeve.
Please keep your experiences coming as this is driving me nuts x(
Thank you! 🙂25 november, 2008 kl. 09:57 #118970fpan
Thanks storfiskarn!
Thank you! 🙂27 november, 2008 kl. 14:15 #118965storfiskarn
DeltagareIm sorry,no plastik on front springs:( my mistake. Did you change the bump stops?
27 november, 2008 kl. 14:15 #118967storfiskarn
4 december, 2008 kl. 12:32 #118971fpan
Yes, the garage took out the old bump stops and used the ones that came with the prodrive springs.
5 december, 2008 kl. 16:15 #118968storfiskarn
DeltagareInside the damper? my garage didnt know that they can take apart?the damper? sorry for my english..
