› SSC › Modellspecifikt › Impreza / STI Racing / BRZ › Motor › Gc8 impreza twin-Dump downpipe
- Detta ämne har 6 svar, 1,302 deltagare, och uppdaterades senast för 18 år, 3 månader sedan av
volvosnubbe.
13 maj, 2007 kl. 17:07 #3736
gt_00
DeltagareWhat shop in Sweden are selling that downpipe whitch have two pipes.
I have seen in many Swedish imprezas that modell. Now i,m looking that to my scooby also.
16 maj, 2007 kl. 16:35 #61045gt_00
DeltagareReally nobody know but so many have those. 🙁 Weird…
I mean that kind of downpipe with have two pipes. (westgate have own)
I,m asking bacause i like to build screamer pipe :).
Here: http://bbs.scoobynet.com/projects-40/544656-wastegate-splitter-screamer-pipe.html
then click wiev full version 🙂
16 maj, 2007 kl. 18:01 #61043Addson
DeltagareDont think anyone in sweden sels that kind of downpipe. I got one but it is from BPM so if u contact them mayby the kan help u.
This is how it looks like
http://www.impreza.nu/ssi2/expo/albums/album374/BPM_twindownpipe_och_GT_muffler.jpg
16 maj, 2007 kl. 18:17 #61041SecretAgentMan
DeltagareThere is an inherent problem with the design of the twin dump downpipes if you’re looking to make a screamer pipe.
The wastegate flapper (the penny on the turbo wastegate axle) will open up towards the ”dump” pipe at an angle, and seeing as you’d need to modify the flange to make the wastegate sealed off from the turbine outlet – to let only the wastegate gasses go to free air (otherwise you’d let exhaust gasses through as well, not only the wastegate for the ”screamer” pipe effect you’re looking for).
This will/can make controlling boost a nasty experience – I tried with a massive turbo that had an enlarged wastegate flapper that opened up very close to the ”dump” pipe on the downpipe, which in turn effectively sealed the wastegate off to use just the said ”dump” pipe (effectively what you’d need to do), and ended up with uncontrollable boost in the higher rpm regions.
I would *not* do it the way you’re thinking about doing it in.
Weld up the wastegate flapper on the turbo, and fit an external wastegate on the upppipe instead, that’s the way to do it.
17 maj, 2007 kl. 10:03 #61046gt_00
DeltagareThere is an inherent problem with the design of the twin dump downpipes if you’re looking to make a screamer pipe.The wastegate flapper (the penny on the turbo wastegate axle) will open up towards the ”dump” pipe at an angle, and seeing as you’d need to modify the flange to make the wastegate sealed off from the turbine outlet – to let only the wastegate gasses go to free air (otherwise you’d let exhaust gasses through as well, not only the wastegate for the ”screamer” pipe effect you’re looking for).This will/can make controlling boost a nasty experience – I tried with a massive turbo that had an enlarged wastegate flapper that opened up very close to the ”dump” pipe on the downpipe, which in turn effectively sealed the wastegate off to use just the said ”dump” pipe (effectively what you’d need to do), and ended up with uncontrollable boost in the higher rpm regions.I would *not* do it the way you’re thinking about doing it in.Weld up the wastegate flapper on the turbo, and fit an external wastegate on the upppipe instead, that’s the way to do it.:)/J
Tack.
Do you know some places in Uk or somewhere who sells that kind of dp what i,m looking for.
Mayby i forget that screamer pipe idea and just bolt that twin pipe dp 🙂
17 maj, 2007 kl. 10:24 #61042SecretAgentMan
DeltagareScoobymania has the nicest one out there (I used to have one on my own car) – it’s 3″ all the way though, so there might be a problem attaching a standard 2.25″ system to the flange on the downpipe.
But let mike@scoobymania.co.uk know Jerry sent you. 😉
Rgds
17 maj, 2007 kl. 15:43 #61044volvosnubbe
DeltagareNu hänger jag inte riktigt med …
Hakar på tråden o frågar .
Jag har 3″ downpipe utan den där WG ledningen . Det är bara en platta över.
Jag tänkte göra som så att ja borrar ett hål o svetsar på en extern WG o tar bort den där ”flippflopp” grejjen i turbon (orginal WG)
Men då e frågan..ja tänkte bara dra ett kort rör efter den externa WG . Så den e öppen.
Funkar detta me Imprezans (GT) system?
DVS mäter lambdan på fullast på Impreza gt ?MVH Dennis
