› SSC › Modellspecifikt › Impreza / STI Racing / BRZ › Allmänt › Luftfilter till Impreza Gt?
- Detta ämne är tomt.
19 augusti, 2006 kl. 21:05 #1085
Itsjustfun
DeltagareHej.
What kind of Airfiler could be good to little trimmad Impreza Gt?
Should i just buy some (panel) Kn,Green,Pipercross or something else Replacement panel air filter wich go to orginal Filter box.
Where i could ask Stock Replacement Air Filters in Stockholm?
Put some store links where i can ask.
Thanks
21 augusti, 2006 kl. 20:16 #42342sti_erik
Deltagare22 augusti, 2006 kl. 09:45 #42339backfeed
DeltagareUnless you really need it, use the stock Subaru air filter. My Impreza had a K&N panel filter (in the original air box) when I bought it, and about six months after the purchase the mass air flow meter broke down.
The problem with most/all filters with increased air flow is simply that they sacrifice filtering for more throughput, letting more dirt pass. The stock mass air flow meter in the Impreza is rather sensitive and has a tendency to break down, so it’s better to use the stock air filter unless you really need the increased airflow.
The stock filter works just fine for me, having increased the max boost pressure to about 1.1 bar (and having a 3″ exhaust system).
I’ve been told the replacement mass air flow meter is less sensitive than stock, but I’m not taking any unnecessary chances.
-= Impreza GT -99 =-
22 augusti, 2006 kl. 18:18 #42341Itsjustfun
DeltagareUnless you really need it, use the stock Subaru air filter. My Impreza had a K&N panel filter (in the original air box) when I bought it, and about six months after the purchase the mass air flow meter broke down.The problem with most/all filters with increased air flow is simply that they sacrifice filtering for more throughput, letting more dirt pass. The stock mass air flow meter in the Impreza is rather sensitive and has a tendency to break down, so it’s better to use the stock air filter unless you really need the increased airflow.The stock filter works just fine for me, having increased the max boost pressure to about 1.1 bar (and having a 3″ exhaust system).I’ve been told the replacement mass air flow meter is less sensitive than stock, but I’m not taking any unnecessary chances.-= Impreza GT -99 =-
Ok.
But but how far orginal can handle? I have heard also that too much if filter have oil that will be dead to air flow meter.
Any idea where ask apexi,hks or greddy turbotimer and wire set?
I also need air/fuel ratio meter. What qould be good and where i could byy that.
23 augusti, 2006 kl. 07:53 #42340backfeed
DeltagareI don’t know how far you can go with the stock air filter, sorry.
You are correct that having too much oil in a reusable aftermarket air filter may break down the air flow meter – oil drops can hit the meter.
The only air/fuel meter i know about is the LambdaLink, but there are most likely more visually appealing alternatives. 🙂
