› SSC › Annonser › Säljes – Delar › Maintenence Services for Subaru!
- Detta ämne har 13 svar, 1,488 deltagare, och uppdaterades senast för 11 år, 3 månader sedan av
Hightone.
28 september, 2014 kl. 15:02 #32943
Hightone
DeltagareFirst let me introduce my self, Im from the USA and been living in Sweden Goteborg for 2 years now, I have owned my subaru and modded for years. I believe a subaru should be properly modded for reliability and everything done correctly the first time.
After years of trial and error with my Subaru I’ve learned that lesson.
Right now my Subaru is down til I get a replacement built block, unfortunely I bought a used engine from Japan and im now there is coolant in the oil.
Saying all that I want to provide my services for anyone with a Subaru, I know how expensive a Mechanic or a Specialist in JapCars is here in Sweden and honestly I think I can provide a better service.
Services I can provide include
Oil Change ; Spark Plugs ; Ball Joints ; Axles ; Brakes; General Maintenence
Services of Installing/Modding parts include
Uppipe, Headers, Downpipe, Turbo, Top Mount Intercooler, Intake Manifold, TGV Deletes, Fuel Injectors, Gaskets, Turbo inlet pipe, Internal Wastegate, 3-port electronic boost controller(Along with a Hybrid setup that consist of a EBC and MBC) etc etc
I can also Diagnose issues that you may or may not have.
I can also do bigger jobs like swapping out your engine.I can also help you get a proper tune for your car, I 100% believe every subaru should have a custom tune, even if its stock. Stay away from cheap things like ”chips”!!
My Swedish is pretty rough, but I do have my loving Girlfriend for translation.
Anywork done would be done at your place as I dont have a big enough garage.
If I have broken any rules on the forum just let me know and il take this down, I did read the Rules of this forum so I think Im covered.
Just shoot me a message with Question and your Email, so that we can continue this by email or phone, and as well as getting you a quote on affordable prices! I Specialize in MY00-07! I of coarse can do work on any other years as well!
29 september, 2014 kl. 10:50 #272706Tgm2
DeltagareGood luck d—0.o—b
I’ll definitely remember this thread for the future, in case I encounter any issues that need troubleshooting.
You’re right, the local (Borås) authorised dealer doesn’t have a clue and the nearest ”specialised” place that I know of is JRM Racing in Stockholm.
29 september, 2014 kl. 13:08 #272698Hightone
Thanks, I actually had a delivery to the Borås Subaru, and just from being there I noticed you are very limited to service, hell any Dealer in Sweden, if I rememebr right has to go thru the boss in Malmo.
The problem I find with specialists is Cost, and minimal options you get.
If I cant find the issue then I wont charge a krown!
Would be unfair to anyone really.I have romraider etc etc on my computer to help with Diagnoses or small edits.
The below setting is my Last tune I was on.
Like I said I modded for reliability not huge power!Gothenborg, Sweden
Elevation:18 m / 59 ftCar: 02 wrx
Tuner: Phatron
Dyno Info: E-tune
Engine: JDM EJ205
Transmission: Stock 5-Speed
Gear: 3th gear
Peak at RPM: 206 WHP @ 5400rpm
Peak Torque at RPM: 216 Torq @ 3900rpmBaseline hp/tq for a stock on same dyno:?
Turbo: TD04HL
Target Boost: 18psi and tapers to 14psi at 7000rpms 😛
Fuel: 93 Pump / 98SwedenEngine/Power Modifications: 3in Decatted downpipe,Stock catted uppipe, K&N drop in filter,3inch midpipe, sti muffler, JDM V7 Intercooler, Sti Pinks, Gimmick Turbo inlet V2,TGV deletes
Compression Ratio: Stock 9:1
Fuel: Single Walbro 255
ECU: Stock USDM wrx ECU
Driveline Modifications: ACT Heavy Duty Clutch, ACT Lightweight Flywheel 12lb
Engine oil: Motul 10w40
Injectors Duty Cycle: 89%ishI have now added more mods but didnt get to tune my car with them since engine is pooped. I was going to get it tuned on e85 as well to drive all year long!
Mods I added were
1000cc Injector Dynamic,
Kinugawa Internal Wastegate 14psi,
IACV Coolant bypass Mod(Free cheap mod!)
Uncatted uppipe,
HKS step 1 colder spark plugs.Hybrid boost controller consisting of 3-port grimmspeed and a hallmans manual boost controller
All mods and work have been done on my own!
I can even help you get some cheap reliable parts!
for example I installed new front axles on my car for 2000sek(including tax!), not cheap axles that will break either, proven reliable!Want help with your winter project? Come to me, I dont care if its cold!
Thanks for reading and hope to get some business done!
4 oktober, 2014 kl. 12:25 #272699Hightone
DeltagareI know some of you guys are starting winter projects!
Need major work done? replacing engine block? Need engine out?
Brake job?To show you how fast I work, I can remove the engine of a subaru in about 1-2 hours, 3 hours tops if its freezing cold!
If you dont have a garage, and winter comes around il find a way to be able to still work on your car! Even if its a big job like Engine removal etc etc!
Dont have the time to do it but dont want to overpay a shop to do a simple job?
Shoot me a message and we can continue it over email!
If you think your English is bad then write to me in Swedish, il get my loving girlfriend to translate!(and google translated —0.o—b )Again Moderators, if there is any problem at all! Please let me know! I know im not a donator of the club yet but would love to get to that!
6 oktober, 2014 kl. 19:54 #272709Javiisst
how much experience do you have in tuning?
6 oktober, 2014 kl. 22:18 #272697karlberg
DeltagareCan u mabye support me when im doing a 6speed convertion on my impreza type r this winter?
Have a garage in central gothenburg 😉
7 oktober, 2014 kl. 12:31 #272700Hightone
DeltagareI have lots of time during the morning and day to be able to work on people’s car’s. Hell if you want me to work on your car while your at work il do that! If you want me to do it outside your job place, im extremely okay with that!
I work 17:00 to 22:00 in my normal job Monday to Friday.
12 oktober, 2014 kl. 16:14 #272701Hightone
DeltagareI am Selling *please note il ship with UPS as I have a huge discount with them as I work with them*
I accept Swish or Paypal, or upfront Cash!
(Used)STI Pink Injectors 550cc TopFeed – 1300sek
(Used)WRX LightBlue Injectors 440cc TopFeed- 500sek
(Used)TGV/motors not ported – 300sek *Can port for additional 700sek*
(Used)Stock boost controller – 200sek
(Used)TD04 Stock Wastegate – 200sek(New)ACT 6 Puck Sprung Replacement Clutch Disc – 1200sek
http://www.advancedclutch.com/6228518
I did open the box to inspect.12 oktober, 2014 kl. 16:15 #272702Hightone
DeltagareDouble post!
26 oktober, 2014 kl. 16:49 #272707Tgm2
DeltagareLet’s chat. I’ve got an issue with my MY09 Forester XT that I can’t get to the bottom of. I’ll send you a PM.
26 oktober, 2014 kl. 20:16 #272703Hightone
Messaged you back!
27 oktober, 2014 kl. 15:46 #272708Tgm2
DeltagareJag har precis pratat med Andy och han verkligen ”knows his stuff”.
Man kan höra klart att han brinner för Subarus och har mycket erfarenhet. Jag ska följer hans rekommendationer och hoppas att det löser min probleme. Tack Andy!
1 november, 2014 kl. 00:42 #272704Hightone
Thanks, I appreciate it!
Anything I can do to help anyone out.30 november, 2014 kl. 02:08 #272705Hightone
DeltagareAnybody got the car down and ready to get worked on?
Contact me if you need me to do it! -
