SSC Allmänt snack Allmänt småprat ”nya ” S.e.c.s för blob/bug
  • #8115
    dlehtihet
      Någon som har kollat in eller kanske rentutav beställt denna till 01-> wrx och sti? Den har nu tydligen en ny displaytyp och finns även med en smutt pod för nyare bilar:
      http://www.ecutek.co.uk/products/dashdisplay/
      //Danne
      #91690
      Yonaz
        Går det läsa felkoder på dennadäringa? 🙂
        #91688
        dlehtihet
          Japp, verkar faktiskt så:
          ”In addition to standard diagnostic functions, such as ECU reset and fault code display, several features are included such as the facility for water injection control control. The unit incorporates display of many ECU parameters, such as boost pressure & RPM, and has user adjustable alarm and data recording facilities. Additional sensors can be added to display exhaust gas temperature and oil pressure for example.
          The monitor reads its information directly from external sensors as well as direct from the ECU via the vehicle diagnostics port. The high data rate allows the display to be updated approximately five times every second.
          The parameters displayed on each screen are customisable and allows the user to tailor the display to their personal preferences. The unit also records peak values of parameters such as RPM & boost pressure.
          The user can set their own alarm limits which when are exceeded, can turn on an external warning lamp.
          Information is displayed on a 2 line by 24-character display and is controlled by 4 buttons. The unit does not interfere with the operation of the vehicle in any way, though since the vehicle only has one diagnostics port, DeltaDash obviously cannot be used at the same time !
          If the ECU has been programmed with the Map Switching / User Tuning functionality then the display will make available the following extra features:
          Map switching may be controlled from and displayed by the dashboard display.
          User Tune parameters may be adjusted. i.e. Parameters such as ignition, fuel, boost, VVT, rev limit and idle speed can all be adjusted if the ECU has been suitably configured.
          This dashboard display uses a high brightness vacuum fluorescent display – many times brighter and clearer than LCD variants, at any viewing angle too. ”
          #91691
          Yonaz
            Gruppköp från England eller kanske genom JRM? :9
            #91695
              Är väl inte direkt svårt att köpa prylar från England? Till och med jag har lyckats med det och då måste det vara enkelt! Sen har JRM säkert nog med jobb utan att vi ber dem beställa prylar åt oss också. 😉
              Såg ut som en trevlig liten pryl. Synd man inte har några hundra pund liggande och samlar damm. 😉
              #91692
              Yonaz
                JRM som är återförsäljare av ecutek i Sverige kanske kan fixa bra priser(samma som privat import)
                Någon som känner att de har ork att ta fram ett pris?
                #91689
                dlehtihet
                  Redan gjort,
                  var i kontakt med dem och de säger att de inte har något återförsäljare i Sverige som har denna i lager nu, därför kan vi beställa den direkt ifrån dem, fraktfritt. Fick detta mail tidigare idag:
                  ”Because we do not have a distributor in Sweden who will have these in
                  stock we would ship this to you free of charge.
                  Therefore the total including shipping to Sweden will be 499.38 GBP inc shipping.”
                  dvs, 6 421,93 SEK (enligt forex idag).
                  Detta priset inkluderar alltså en ”pod” för blob/bug modellerna som färgmatchar väldigt fint.
                  //Danne
                  #91693
                  pannan
                    Ser ut som en datalogger som EcuTek har satt sitt namn på.
                    http://www.scoobyworld.co.uk/trolleyed/2/15/index.htm#secss1001
                    Finns även två filmer ni kan ladda hem här och se hur den fungerar. Riktigt schysst liten pryl som håller reda på en mängd funktioner ifrån ECU:n
                    #91694
                    Larry
                      Undrar om man skulle kunna koppla en flödesmätare
                      för bensintillförseln till den där lilla maniken.
                      Kunde vara intressant…
                      Den verkar vara pratbar för olika givare, eller
                      har jag fatta fel?
