SSC Annonser Säljes – Delar OEM delar til justy
Visar 1 inlägg (av 1 totalt)
  • #34642
    jonarnes
      Hej!
      Legger ut min annonse fra ebay. Tar også imot bud!
      http://www.ebay.com/itm/331831520062?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649&rmvSB=true
      I have got my hands on a lot of original subaru parts (new, old stock)
      Some parts also fits domingo, Libero, E10 E12
      I want to sell them altogether. Will ship worldwide.
      I had some difficulties to check the parts number. Would recommend to double check if you are in doubt.
      1x Cap assy dist (justy KAD 86-95 1200cc) 22162ka100
      1x Cap assy dist (justy KAD 1990-94, Libero/ domingo E10, E12 1991-00) Subaru vivio? 22162ka181
      2x Rotor (corolla, justy KAD 90-94 + more) 22157ka040
      2x Rotor (Domingo e10+e12, Leone, Daihatsu charade 83-92, and alot of suzukies) 22157ka020
      1x Reverse backup switch (Justy 1990-94) 32005ka100
      1x Thermostat. Justy (90-94) 21200ka131 Cross numbers: SUBARU 21200KA130 SUBARU 21200KA131 TRISCAN 862011277
      1x Clutch pressure plate Justy 1 KAD, Libero E10/12. engine: 1000ccm 50-54hk 430155910
      1x Indicator/ turn signal lamp on fender Justy 784401400
      2x Front brake disk. Justy KAD 84-94 Libero 83- 2000 725431312
      2x Wheel bearing kit front Justy 1,2 87-89 2wd and 4wd 799923110
      2x Single wheel bearings front Justy 1,2 87-89 2wd og 4wd 906010021
      1x Timing belt Tensioner Justy 86-94 13070ka020
      1x Front exhaust gasket Justy 90-94 44222kc000
      1x bolt for timing belt cover Justy 87-94 13260KA001
      Seal crank Justy EF10A 84-86 806760010
      Seal wheel bearing rear Justy 87-94 906390005
      Seal Justy, domingo, sumo D11, E10 E12 84-00 ef12 806723030
      Seal camshaft Justy 87-94 806730150
      3x seal camshaft Justy 87-94 1,2 806738170
      1x Dust cover strut Justy 87-94 rear 721057150
      1x Rotor Justy 84-94 1,2 22157ka000
      1x Rotor Justy 84-94 1,2, Mazda 323 85-91 22157aa040
      1x Distributor Justy 87-93 1,2 22162ka050
      1 x Distributor Justy 84-95 491005501
      1x Brake shoe kit Justy rear 90-94 725178481
