Hi!
I am looking for the original plug that goes above the cylinder #3 for the oil temperature sensor.
I want to remove the oil temperature sensor but do not have the plug to put back in place.
Regards,
Fivos
I have that plug for EJ20/(EJ22). I am willing to swap plug with you so that i can have an oil temp sensor.What threading do you have in the plug? NTP?
Hi,
I am not sure as I don’t have the car anymore, it is with the insurance. The problem is I need to go to Vaxjo where the car is located to remove the sensor and put back the plug so I need the plug beforehand.
The oil temp sensor itself is the ’plug’ at the moment and I would like to sell both the oil temp and oil pressure sensors together with the instrument (but can separate).
The car is a 2007 WRX.
I will connect some standard Bosch or VDO sensor and connect it directly to the Autronic. The temperature can then be read with a dash display connected to the Autronic, as well as the Autronic can use the sensor itself for protecting the engine from damage.
I am not interested in the instrument.
But if you want to swap plug with me the plug is at Ljusterö, near Stockholm.
Författare
