› SSC › Modellspecifikt › Impreza / STI Racing / BRZ › Allmänt › Reperationshandbok GT-99
- Detta ämne har 3 svar, 1,056 deltagare, och uppdaterades senast för 18 år, 7 månader sedan av
rickey.
22 februari, 2008 kl. 12:25 #1453
rickey
DeltagareFinns det en reperationshandbok motsvarande Haynes för Imprezan?
23 februari, 2008 kl. 00:36 #45026RXY430
DeltagareDet här finns ju http://www.autodata.ltd.uk/
Kopierar in en text om autodata som jag hittade med google:
”AUTODATA 3.18 2007
Autodata 3.18 – complex
multibranded information base on diagnostics and car repairs till 2007 of
release.
In Autodata are included following marks – Alfa Romeo, Audi, BMW, Chrysler,
Citroen, Daewoo, Daihatsu, Fiat, Ford, Honda, Hyundai, Isuzu, Jaguar, Jeep, Kia,
Lada, Lancia, Land Rover and Range Rover, Lexus, Mazda, Mercedes-Benz,
Mitsubishi, Nissan, Opel/Vauxhall, Peugeot, Porsche, Renault, Rover, Saab, Seat,
Skoda, Subaru, Suzuki, Toyota, Volkswagen, Volvo. On these marks, basically,
detailed data are included. In Autodata there are also other world marks
(including lorries and a tractor).
Autodata contains following sections:Technical data –
characteristics and adjusting data on the car. This section is divided in
Autodata into some subitems:The basic characteristics – number of cylinders,
volume and type of the engine, the power, demanded fuel, ignition system
(the manufacturer, type), fuel system (the manufacturer, type) etc.
Detailed data of ignition system – characteristics
of the coil of ignition (a working voltage, resistance of windings), the
operating procedure of cylinders, management of an advancing of ignition),
turnovers of idling, normative data on СО/CH/CO2/O2, used type of spark
plugs, a normative interval between electrodes of spark plugs, etc.
Detailed data on fuel system – pressure of fuel,
etc.
Various help data – a compression, pressure of
oil, resistance of various connectors, atomizers, etc.
Refuelling capacities and used liquids – used
engine and transmission oils (with gradation as a climate), liquids for
brake system, system of cooling, the hydraulic steering management, etc.,
filled in volumes;
Specifications of an inhaling of connections;Data on electro system, start and charging system
– voltage and capacity of the battery, starter and generator data;
Other information.Repair times – the basic norms of time for repair
operations;
Wheel alignment – data on installation of wheels –
wheel base, a track, specifications of an inhaling of wheel bolts, corners
of installation of wheels, requirements to loading the car at adjustment of
corners of installation of wheels;
Timing belts – installation and adjustment of
belts with illustrations, order of removal and installation of belts, etc.
Service schedules – service intervals and service
operations;
Service indicator and key programming –
Programming procedures for ignition keys central locking, immobilisers and
alarm systems, electronic locks (for those cars where these
operations probably to lead without use of the special equipment);
Accessing trouble codes – work with codes of
malfunctions errors – procedures of reading and deleting of codes of
malfunctions (for those cars where these operations probably to lead without
use of the special equipment), tables of decoding of codes of malfunctions;
Engine management component testing – wiring
diagrams of control systems of the engine, an arrangement of components of a
control system of the engine (with illustrations);
Engine management pin data – a kind and
destination of conclusions of a socket of the electronic block of management
with the detailed description on each socket (with what connector or the
executive mechanism it is connected, entering/proceeding, normal value of
voltage, installation of an oscillograph for viewing the signal, the
reference form of a signal);
Engine management trouble shooter – lists of
checks for elimination of typical malfunctions;
Airbags – the detailed information on system of
safety – an arrangement of components of system (airbags, belts pre-tensioners, blocks of
management of safety) etc;
Air conditioning – the detailed information on a
central air – diagnostics of pressure in system, diagnostics by means of
codes of malfunctions, adjusting parameters, the wiring diagrams of a
control system, an arrangement of components, etc;
Anti-Lock Brake systems – the detailed information
on antiblocking system (ABS), testing of separate components of system, the
wiring diagrams of a control system, an arrangement of components of a
control system (connectors, the block of management, safety locks, the pump,
the relay, etc.);
Component locations – an arrangement of electronic
and mechanical components on a control system of the engine,
air-conditionings, ABS, destination and an arrangement fuse box and relay
plates – layouts and values;
Wiring diagrams – electro schemes of control
systems of the engine, air-conditionings, ABS.
All sections of base are logically interconnected – for
example, opening section ”Airbags”, ” Air conditioning ” or ” Anti-Lock
Brake systems ” you in the concentrated kind receive the full information
particularly on the chosen system: on an arrangement of components, methods
of check of separate components of system, etc. Considering the size of
Autodata and quantity of marks it is necessary to consider adjusting
parameters, the electroscheme, the information, that the quantity of the
information on different marks and models essentially differs!”23 februari, 2008 kl. 21:53 #45027MariaimprezaGT
Deltagarevill påstå att de är en rätt dyr handrepbok.. 😀
Men jävligt bra =)
Maria
Audi is teh ####!!
23 februari, 2008 kl. 22:02 #45028rickey
DeltagareJag har hört att den även finns på internet… :+
