SSC Annonser Säljes – Delar S: AEM RACE SPRUT (GEMS 15 )
  • #20178
    Subarumicke
      http://i102.photobucket.com/albums/m102/subarumicke/2007-02-10004.jpg
      http://i102.photobucket.com/albums/m102/subarumicke/2007-02-10003.jpg
      http://i102.photobucket.com/albums/m102/subarumicke/2007-02-10002.jpg
      http://i102.photobucket.com/albums/m102/subarumicke/2007-02-10001.jpg
      GEMS has developed a powerful ECU in association with AEM Power Inc. http://www.aempower.com
      This ECU is available either as a stand-alone unit or as a plug and play system where the GEMS 15 replaces the factory unit and uses the existing loom and sensors. A universal wiring harness and sensors are available for easy installation into none plug and play applications.
      Features
      *User configurable Windows software.
      *Onboard Data logging.
      *Comes with complete library of tuning tips and system design.
      *User programmable inputs and outputs. Number of spare inputs and outputs vary with engine configuration.
      *Up to 10 cylinder sequential fuel injection with individual cylinder trim.
      *Up to 10 cylinder wasted spark distributor less ignition with individual cylinder trim.
      *Boost Control.
      *Comprehensive Nitrous Control.
      *Twin O2 sensor closed loop control (Wide range, and UEGO).
      *Comprehensive easy to follow wiring instructions.
      Exhaust Gas Temperature (EGT) feedback.
      *Idle motor control.
      *Extensive Electronic Automatic transmission control.
      *16/32 bit High Speed Processor.
      *Interactive User Friendly manual.
      *Twin Knock sensing control.
      *Twin Channel Variable Valve Control.
      *A wide range of plug and play applications are available and come complete with a base
      *calibration for the stock engine.
      *Available with 2×36 way connectors for custom application.
      Mjukvaran i boxen just nu är SUBARU IMPREZA, Säljer sprutet pga.. har inte kunskapen att flytta över den till mitt andra projekt 🙁 , ska köpa Plug and Play i stället Sprutet kostade 28000 kr nytt och jag säljer det för 20000kr kan disk.. beroende på vad som ska följa med
      Pris: 20000 kr
      bernan@comhem.se
      Tel:0708419962
      OBS om det är någon som bygger mera race betonat så har jag även MSD Tändspolar mm fuelrails mm.. liggandes
      #180380
      Subarumicke
        15000 kr, ingen som ska trimma??
        #180381
        Subarumicke
          OBS EJ TILL SALU
          #180382
          Subarumicke
            OBS: NYTT PRIS 9000 kr
