SSC Allmänt snack Allmänt småprat Trackday Impreza
  • Detta ämne har 1 svar, 828 deltagare, och uppdaterades senast för 19 år sedan av OzO.
  • #10118
    555_STI
      http://www.adrenalinemotorsport.co.uk/index.html
      Nån som är sugen att kapa sonder deras Impreza? 🙂 Jag skulle inte kunna göra det rent känslomässigt
      –SNIP–
      The Murtaya has been carefully designed to offer an exciting and straightforward project for home assembly. The only donor parts required are sourced from a single donor vehicle, the classic shape (1993-2000) Subaru Impreza in either normally aspirated or turbocharged form.
      For the ultimate donor an Impreza Type R or Type RA should be sought. Although rarer, harder to find and more expensive, the list of competition homologation special components fitted as standard to these models create an incredible donor package that will build into a
      sensational sportscar.
      http://www.adrenalinemotorsport.co.uk/performance.htm
      #112098
      OzO
        Kapa sönder en Type R or Type RA? Aldrig! Och inte heller skulle jag smäcka dit en sån ful kaross… :+
        /G
        _____
        ::::: | ”I would be unstoppable… if I could just get started!” | :::::
