SSC Annonser Säljes – Delar Turbo MD321H (400bhp) Billet
  • #27340
    griml0ck
      Helt ny aldrig använd. Ligger fortfarande i förpackningen som är oöppnad. Perfekt för den som ska ha 400++ o vill ha en bil med härlig spool up. Går att ladda upp åt 1.6-1.8 beroende på motor.
      Specs från hemsidan:
      http://lateralperformance.co.uk/product.php/180/0/md321h__400bhp__billet
      Enlarge MD321H (400bhp) Billet
      Working closely in partnership with Turbo Dynamics, Lateral Performance’s new series of MD321 Turbos use custom billet compressor wheels further enhancing what has become a world renowned turbo range.
      Milled from custom 2618 T61 billet forgings, their strength exceeds the material properties of normal aluminium cast wheels allowing new high tech designs for reduced lag and improved airflow.
      Such is the confidence of Lateral Performance and Turbo Dynamics that all the new billet MD321 series turbos will carry a 2 year warranty against component failure.
      The MD321H is superbly suited to 2.0lt cars aiming for 400bhp, where spool up, and throttle response is even more stunning with the billet wheel, and it can achieve this at circa 1.45bar.
      For those with stronger built engines, and able to run higher boost, 420-430bhp is achievable.
      The MD321H comes with a 58mm intake as standard. All turbos come with water pipes, steel gaskets, studs, braided oil feed pipe & oil pressure restrictor/adapter fitting.
      Passar bolt on på GC8.
      Pris: 13 000 kr
      Ny pris är £1674.00 + frakt
      #233700
      Gyver
        Telefonnummer att nå dig på?
        /David
        #233698
        griml0ck
          070 398 29 68 (johan)
          #233699
          griml0ck
            *såld*
