› SSC › Annonser › Säljes – Delar › Exedy hyper dubbelskivig koppling
  • #21170
    STIred
      Hittade även en fin bild på den.
      http://image.turbomagazine.com/f/12197172/turp_0812_25_z+subaru_wrx_sti_buyers_guide+exedy_hyper_twin_clutch.jpg
      Kopplingen är i princip ny. Tillhörade svänghjul och tryckplatta medföljer. Pallar massor med vrid.
      Här kommer lite klippt och klistrat:
      ”The twin plate clutches are rated for above 500HP to 750HP. The triple plate clutches are rated for up to and over 800TQ @ FW (for drag race applicatoins). Twins come with both spring damper discs and solid discs. Triples are all solid discs and not recommended for road use.
      All of the multi-plate clutches come with a lightweight, chromemoly steel flywheel and the famous purple anodized forged aluminum clutch cover. All have T5001 cerametallic friction materials for extreme heat resistance.
      Engine modifications e.g. cam-timing-turbo modifications etc. cause engine pulsatoin and vibrations. These vibrations can cause clutch rattle when the clutch pedal is depressed by movement on the intermediate separator plate in some applications. These noises will in no way affect the performance of the Exedy Multi Plate Clutch. This rattle is well accepted in the performance industry where engine modifications have been carried out.”
      Pris: 13500kr. Svårt att hitta en bättre koppling än denna till ett billigare pris.
      /r
      #184025
      STIred
        Glömde skriva att det går bra skicka PM vid intresse eller maila rtimbus@hotmail.com
        /r
        #184026
        STIred
          Nypriset på denna koppling ligger på runt 18k. Och eftersom jag fått frågan ett par ggr. kan lika gärna skriva det här med, den har gått knappt 300mil normal vardagskörning.
          /r
