› SSC › Modellspecifikt › Impreza / STI Racing / BRZ › Väghållning › Tein Flex Z or Mono Sport? + EDFC
- Detta ämne är tomt.
20 juni, 2017 kl. 07:09 #35454
Pepepapa
DeltagareHi Guys,
I would ask a little help before my final decision of my new coilovers.
I decided to buy Tein coilovers.
Flex Z what i would choose(twin tube structure is better for street).
But does anyone have experince of them, spring rate is not to soft? (7kg/5kg) It would be my first coilover so no idea i have.Mono Sport is almost double price(Monotube structure,better for track, easier to damage on street) and it has higher spring rate (10kg/8KG).
Please share your experiences to help me for the final decision.
Other thing i tought to buy Flex Z with EDFC active damping control, but i have no idea is it good to spend money on it?
Is it fast enough with G sensor?
What effect does it have for the liftime of the damper because it is in move always? (maybe a solution for lifetime to use it in manual mode and use G sensor on race track only)Thank you for the help !
Car is impreza STI 2011 sedan
20 juni, 2017 kl. 08:14 #286802Fladric
DeltagareHi Guys,
Hi!
I don’t have any experience with either of them but I’m happy with the Tein coilovers I have tried 🙂 Would think the Flex Z is nice on a street driven car because they are a bit softer 🙂
Have you considered Öhlins Road and Track?
https://www.ohlins.com/product/road-track/subaru-impreza-sti-racing-2007-2011-grb/
Guessing better support with lots of knowledge closer than for the Tein coilovers 🙂 And I would guess easier with spare parts further down the road!
Nothing bad about Teins, just giving you options 🙂
20 juni, 2017 kl. 08:22 #286805Pepepapa
DeltagareHi!
Hi,
Thank you for info, Öhlins is a bit expensive for me
i use the car in every 3-4 weeks (somethis more times).Trackdays maybe 1-3 times a year.
Do you know the 10kg/8kg hardness how should i imagine? It kick my ass on streets or can be used on street but will be a little bit harder?
Or the same for the flex z which is softer- what should i wait of it? Similar like the original or harder/softer?
Thanks for the help!
Sent from my SM-G930F using Tapatalk
20 juni, 2017 kl. 09:11 #286803Fladric
DeltagareLast time i checked, I think they retailed for around 25000 SEK s (the Road and Track version) so shouldn’t be that big of a difference compared to the Mono Sport? 🙂
Sorry, don’t know what spring rates I had on my coils but from memory of other persons experiences I think 10 is a bit stiff on the street 🙂
Hi,
20 juni, 2017 kl. 09:32 #286806Pepepapa
DeltagareThanks for the info,
Maybe i would lean for hks hypermax 4 gt also, but for price and usage flex z what i like, just don’t know how hard it is
20 juni, 2017 kl. 09:46 #286804Fladric
Sounds like a good plan 🙂 Negative side of the HKS ones are that thay are not intended to be rebuildable if I remember correctly? Might be som older versions though…
Think Goffemannen is running Tein Flex on his GC8!
http://www.subaruclub.se/forum/showthread.php?t=87347
Worth reading the thread and asking him 🙂
20 juni, 2017 kl. 09:48 #286807Pepepapa
DeltagareYeah you are right, hks is not rebuiltable :/
Tein will be my way.
20 juni, 2017 kl. 10:45 #286801goffemannen
Deltagareyes I run Flex on my GC8. They work great for the road and a little track.
20 juni, 2017 kl. 10:46 #286808Pepepapa
DeltagareThanks!
20 maj, 2020 kl. 00:49 #286809iecd_sti
DeltagareHey man, what did you end up buying? I’m also thinking of buying coilovers but have no idea which ones.
