› SSC › Allmänt snack › Projekt › Usdm 02 wrx
- Detta ämne har 100 svar, 17,602 deltagare, och uppdaterades senast för 9 år, 1 månad sedan av
Hightone.
18 november, 2016 kl. 19:33 #276507
Kvarnis
DeltagareImpressive, a calix/deffo is 550w.
So want be a problem unless you move way up north;)3 december, 2016 kl. 15:19 #276577Hightone
Deltagare1 januari, 2017 kl. 18:41 #276578Hightone
DeltagareHavnt done a update in awhile, have ALOT of goodies coming 😉
For now I decided to polish up the exhaust, i removed the tape off it with white spirit, then bought Silverware polish.
Im sure Autosol would be better but I couldnt bother to visit a store that carries it.Not the final finish in the pic but just the product I used 🙂
If you scroll up a post or two you can really see the difference 🙂 looks like a complete different exhaust!
14 januari, 2017 kl. 13:20 #276579Hightone
DeltagareI have done a 03+ STI steering wheel swap, I knew the wiring was different but didnt know it was much different. Reading guides and such it seemed like I would have to cut my clockspring and the sti clockspring to make it work.
I found a easier way, I swapped the Airbag discharged unit around since its the same unit. The wiring for it is the same but the initial clip in slightly different.
I also cut a hole on the side to fit my cruise control.
Odd how no EDM WRX or STI came with it.21 januari, 2017 kl. 20:39 #276580Hightone
Deltagare22 januari, 2017 kl. 12:10 #276529Igge
DeltagareI like both the steering wheel and the coils.
What springs did you have at Gröndal?
22 januari, 2017 kl. 15:39 #276517Christian S
DeltagareBefore you put the coilovers on you car i recommend you to take of the lower part and put some 5-56/WD40 or similar on it so it wont get stuck and you wont be able to change the height on the car.
22 januari, 2017 kl. 15:46 #276581Hightone
DeltagareIgge, I was running stock sti struts F/stock, R/Prodrive springs.
Christian, the bottom piece have already been taken apart and shot with WD40 🙂
To extend the life and prevent any dirt/rust issues, coilovers¨covers will be made that will cover all threads and locks.
Wont be mounting them until April most likely.
I have much more mods coming in soon 🙂 Pics will be up in 1-2 weeks!
22 januari, 2017 kl. 16:27 #276582Hightone
DeltagareScrew it, il post what I have right now.
Full STI rear end swap going in. So far right now I have Complete rear hubs, sti brembo with EBC reds, arms etc, and axles,(have disc too but they need replacing), R180 will be ordered from UK Tuesday.This will be interesting to have since my r160 is so worn it acts like a open diff, I do have a spare diff laying around to swap in but no point now. Going around corners I had so much understeer until my tires warmed up. Hopoefully the R180 will solve this abit.
23 januari, 2017 kl. 06:15 #276518Christian S
Deltagarewhat ratio du you have on the rear diff? I have one in my garage from a new age JDM STI with 3,9 ratio:D if you need I also have front and rear driveshafts and one propshaft from a 04 USDM STId—0.o—b
23 januari, 2017 kl. 19:16 #276583Hightone
I have the 3.54, the diff im getting from the UK is 3.54 as well.
Only costing me 1600sek hahahahahI would love to pick up the 3.9 since I plan on doing a JDM 6 speed swap in summer. Let me know how much you would want and maybe we can work something out.(For diff and prop, shafts are bonus.)
6 februari, 2017 kl. 21:12 #276584Hightone
Deltagare7 februari, 2017 kl. 07:12 #276508Kvarnis
DeltagareNice, the STI is so much more fun then non STI 🙂
26 februari, 2017 kl. 20:56 #276585Hightone
Deltagare10 mars, 2017 kl. 21:07 #276586 -
