› SSC › Allmänt snack › Projekt › Usdm 02 wrx
- Detta ämne har 100 svar, 17,602 deltagare, och uppdaterades senast för 9 år, 2 månader sedan av
Hightone.
2 augusti, 2016 kl. 18:02 #276567
Hightone
DeltagareUK STI PRODRIVE Cluster, I desoldered the EEPROM chip and will be reprogramming it to match my car mileage.
This mod is abit easier to do since my USDM Cluster in miles not KM.My first thought was just to swap the chips around and have it work, but turns out that EEPROM chip somehow ties into the STI shift light, which I do want functioning. Already have a friend building me the chip reader/writer.
7 augusti, 2016 kl. 11:44 #276568Hightone
Deltagare10 augusti, 2016 kl. 17:03 #276569Hightone
Deltagare13 augusti, 2016 kl. 13:28 #2765701 november, 2016 kl. 13:32 #276571Hightone
Deltagare1 november, 2016 kl. 23:29 #276572Hightone
DeltagareGoodies arrived! 05 STI aluminum control arms (Time to add some major castor!)
Oil Filter, PVC replacement, JDM STI Red hazard buttom (JDM TIGHT YO) Motul X-Clean 5w30(Was supposed to be 5w40 but they messed up my order, got refunded quite abit!)
Closer up picture incase you want part numbers for pvc replacement which should be done every 50000km, and also JDM hazard button.
Started cleaning them up abit :)These should have abit more castor built into them, and I will buy ALK whiteline, along with another trick to try getting the perfect castor 🙂
One more goodie is supposed to arrive from the US soon! Will update again neat future.
2 november, 2016 kl. 09:54 #276505Kvarnis
DeltagareNice 🙂
2 november, 2016 kl. 22:26 #276573Hightone
DeltagareThanks! On its way from the US is Subaru OEM Block heater (#A0910AS100) I searched for EU subaru OEM but seems like this was only available to US and Canada. Adapter is cheap and easy to fit.
Other reason I went with Subaru unit is because its only 350sek vs aftermarket which is triple that if not more.
Will post a picture when it arrives!
13 november, 2016 kl. 00:26 #276574Hightone
Deltagare17 november, 2016 kl. 10:03 #276603Adelante
DeltagareWhen you changed the Speedometer etc to the STI one.
How come you sticked with imperial units instead of going for a metric one? 🙂17 november, 2016 kl. 23:31 #276536Hightone
How come you sticked with imperial units instead of going for a metric one? 🙂Well, two reasons.
1 : it was 900sek
2 : it has both mph and kph on both clusters so it doesnt bother me at all 🙂18 november, 2016 kl. 07:47 #276604Adelante
DeltagareWell, two reasons.
1 : it was 900sek
2 : it has both mph and kph on both clusters so it doesnt bother me at all 🙂Well fair enough! 🙂 Very nice upgrade tho 🙂
18 november, 2016 kl. 11:49 #276575Hightone
DeltagareWell fair enough! 🙂 Very nice upgrade tho 🙂
for the money I agree!
18 november, 2016 kl. 14:11 #276506Kvarnis
DeltagareThat heat plug looked very tiny, how many W does it produce?
18 november, 2016 kl. 19:26 #276576Hightone
400w, if its good enough for cold canadian weathers then its good enough for here 😀
